CMP integration with Matomo can be implemented using the Matomo tracking code or Matomo Tag Manager. The Matomo Tag Manager method is covered in a separate guide.
This guide focuses on three consent methods using the Matomo tracking code. Each method is based on different regulatory requirements, so it is important to consider your organisation’s legal obligations and tracking needs when integrating the CMP:
  1. Consent-based Tracking: For websites targeting users in countries that require prior consent for use of cookies and similar technologies for analytics and marketing (for example, most or EU and EEA countries), enable cookieless or cookie-based Matomo tracking only after obtaining visitor consent.
  2. Opt-out Tracking for CNIL Exemption: For organisations relying on the CNIL consent exemption for website analytics, limited tracking is permitted, provided that conditions of exemption are strictly met and users are offered a clear opt-out mechanism. CNIL exemption is strict and if any conditions of the CNIL exemption are not met, consent is also required.
  3. Adaptive Tracking: For websites operating outside the EU/UK/EEA, in countries where prior consent is either not required or only required when the analytics processes personal data, you can enable cookie-based tracking with consent and fallback to cookieless tracking if consent is not given (unless the visitor opts out of all tracking).
Before you start
  1. Create your Osano account.
  2. Complete the necessary steps to configure your cookie banner in line with the consent method used and the legal requirements that apply to your website.
  3. Follow the Osano instructions to add the script to your website’s code. The script must be placed as the first element inside the <head> tag on every webpage you want to track.
  1. If you do not have the tracking code installed yet, go to Matomo > Administration Settings gear Icon > Websites > Tracking Code and select the website you want to track.
  2. Copy the tracking code shown in the code box and paste into a text editor.
  3. Insert the line _paq.push(['requireConsent']); before _paq.push(['trackPageView']).
  4. Paste the modified tracking code inside the <head> tag on all the website pages you are tracking.
  5. If you already have the Matomo tracking code on the page, replace it with the updated tracking code:
<!-- Matomo -->
<script>
  _paq.push(['trackPageView']);
  (function() {
    var u="//matomo/";
</script>
<!-- End Matomo Code -->
The following script listens for consent updates and enables/disables tracking when consent is granted/denied.
Add the consent handling script before the closing </head> tag on all website pages that contain the Matomo tracking code.
<script>
var waitForTrackerCount = 0;
  if (typeof _paq === 'undefined') {
      waitForTrackerCount++;
      return;
  } else {
    Osano.cm.addEventListener('osano-cm-initialized',
      (change) => { consentSet(window.Osano.cm.getConsent()); });
    Osano.cm.addEventListener('osano-cm-consent-changed',
      (change) => { consentSet(change); });
function consentSet(change) {
  if (change.hasOwnProperty('ANALYTICS') && change.ANALYTICS === 'ACCEPT') {
  } else {
document.addEventListener('DOMContentLoaded', matomoWaitForTracker());
</script>
Validate the Integration
  • To simulate different locations, use a VPN during testing.
  • Open your website and use the CMP widget to decline tracking consent.
  • In your Matomo instance, select the Visitors > Real-time report, and check that no tracking requests are sent.
  • Next, grant consent and verify that tracking starts in your Matomo instance.
  • If using cookie-based tracking, open the browser’s developer tools and view the Application or Storage > Cookies tab to confirm cookies were set.
  • Revoke consent and confirm the Matomo tracking cookies are deleted from the browser.
  • Perform some test actions and check your activity was not recorded in the Visits in Real-time report.
  1. Your website targets visitors in countries where CNIL or very similar exemption exists (e.g., France, Spain, Italy), or you have an establishment in such countries:
    • Configure your CMP to either load Matomo Analytics cookies and start tracking without prior consent, or
    • Re-categorise the Matomo cookies as Essential/Necessary.
    • The CMP banner must clearly inform users about the use of consent exempt website analytics tracking and include a visible and easily accessible opt-out mechanism (e.g. a link to your privacy policy with an opt-out checkbox).
      opt-out form matomo
  2. If your website serves a broader audience that targets visitors from countries that require prior consent for cookie based or cookieless website analytics (e.g. most of EU countries):
    • Consider splitting your banner configuration if the CMP supports region-specific geotargeting and consent rules.
  3. Follow the steps in this guide, How to include a web analytics opt-out feature on your site to add the embedded Matomo opt-out form to your website. The form includes all required JavaScript to allow users to opt-out of tracking.
  4. Alternatively, you can create a custom opt-out form using HTML and JavaScript, as explained in this developer guide.
  • Perform test actions on your website and view the Visits in Real-time report to verify tracking requests are sent to Matomo.
  • Select to opt-out of tracking.
  • Open the browser’s developer tools and view the Application or Storage > Cookies tab to verify that the mtm_consent_removed cookie is set.
  • Perform test actions on your website and view Visitors > Real-time report to ensure no tracking requests are sent to Matomo after opting out.
  • Change the settings to opt back in and resume tracking.
  • Perform test actions on your website and view the Real-time report to ensure tracking requests are sent to Matomo.
Method 3: Adaptive Tracking
  • are not legally required (but you want to minimise the data you collect),
  • are not required for pseudonymised non-sensitive personal data or
  • are only required if certain personal data is processed.
  3. Insert the line _paq.push(['requireCookieConsent']); before _paq.push(['trackPageView']).
<!-- Matomo -->
<script>
  (function() {
    var u="//matomo/";
</script>
The following script listens for consent updates and enables/removes cookies when cookie consent is granted/denied.
<script>
      return;
  } else {
  } else {
    _paq.push(['deleteCookies']);
</script>
  • Open your website and use the CMP widget to decline cookie consent.
  • Use the browser’s developer tools and view the Application or Storage > Cookies tab to confirm cookies were not set.
  • In the Visitors > Real-time report, check that tracking requests are still sent.
  • Next, grant / revoke consent and confirm cookies were set / removed as expected.
Previous FAQ: How to integrate OneTrust CMP with Matomo
