How to integrate Tarte au Citron CMP with Matomo
Tarte au Citron is a widely used French open-source consent manager (CMP) that includes built-in support for Matomo, third-party blocking and configurable language options. CMP integration with Matomo can be implemented using the Matomo tracking code or Matomo Tag Manager. The Matomo Tag Manager method is covered in a separate guide.
This guide focuses on three consent methods using the Matomo tracking code. Each method is based on different regulatory requirements, so it is important to consider your organisation’s legal obligations and tracking needs when integrating the CMP:
Before you start
- Create your Tarte au citron cloud account.
- Optionally, Tarte au Citron can be downloaded from Github and installed locally without an account.
- In the Tarte au citron account dashboard, click the three vertical dot menu and select Install.
- Copy the consent manager initialisation script and place it in your web pages. It must be the position you defined in Tarteaucitron > Options > Accessibility settings: after the opening
<body>tag (recommended) or before the closing</body>tag. - Complete the necessary steps to configure your cookie banner in line with the consent method used and the legal requirements that apply to your website.
- If using Method 1 or 3 (described below), ensure the Tarte au citron Conformity settings are configured. Click the three vertical dot menu and select Options > Conformity settings:
- Enable the explicit consent mode (recommended).
- Default services status: set to Waiting user reply.
- The Conformity settings may differ if implementing Method 2 (described below).
Use Automatic or Manual mode
Once your account is set up, you can run Tarte au citron in Automatic or Manual mode.
- Automatic mode detects the Matomo tracking code and consent handling script on your site with minimal configuration in the CMP.
- Manual mode requires more steps to manually configure the consent manager:
- Go to your Tarte au citron > Manage my 0 services, and search for Matomo.
- Add and configure the Matomo service by entering your Matomo instance details. You can get the instance and tracking details in Matomo settings (Administration)
> Measurables > Tracking code.
- If you do not have the tracking code installed yet, go to Matomo > Administration
> Websites > Tracking Code and select the website you want to track. - Copy the tracking code shown in the code box and paste into a text editor.
- Insert the line
_paq.push(['requireConsent']);before_paq.push(['trackPageView']). - Paste the modified tracking code inside the
<head>tag on all the website pages you are tracking. - If you already have the Matomo tracking code on the page, replace it with the updated tracking code:
<!-- Matomo -->
<script>
_paq.push(['trackPageView']);
(function() {
var u="//matomo/";
</script>
<!-- End Matomo Code -->
Install the Matomo consent handling script
The following script listens for consent updates and enables/disables tracking when consent is granted/denied. Add the consent handling script before the closing </head> tag on all website pages that contain the Matomo tracking code.
Note: Ensure the Tarte au Citron script is loaded before calling tarteaucitron.init().
<script>
var waitForTrackerCount = 0;
if (typeof _paq === 'undefined' || typeof tarteaucitron === 'undefined') {
waitForTrackerCount++;
return;
// Initialise Tarteaucitron after the tracker is loaded script
tarteaucitron.init({
//optionally add non-default Tarteaucitron configs here
tarteaucitron.services.MatomoAnalytics = {
"key": "MatomoAnalytics",
"type": "analytic",
"name": "Matomo Analytics",
"needConsent": true,
"cookies": ['_pk_id','_pk_sess','_pk_ref'],
"readmoreLink": "/custom_read_more", // If you want to change readmore link
"js": function () {
"use strict";
// When user allow cookie
('Matomo cookies accepted');
"fallback": function () {
"use strict";
// when use deny cookie
('Matomo cookies rejected');
_paq.push(['deleteCookies']);
// Ensure that tarteaucitron is loaded before pushing the job
tarteaucitron.job = tarteaucitron.job || [];
tarteaucitron.job.push('MatomoAnalytics');
document.addEventListener('DOMContentLoaded', matomoWaitForTracker);
</script>
Validate the Integration
Configure the Consent Manager
- Perform test actions on your website and view the Visitors > Real-time report to verify tracking requests are sent to Matomo.
mtm_consent_removedcookie is set. - Perform test actions on your website and view the Real-time report to ensure no tracking requests are sent to Matomo after opting out.
- Perform test actions on your website and view the report to ensure tracking requests are sent to Matomo.
Method 3: Adaptive Tracking
- Insert the line
_paq.push(['requireCookieConsent']);before_paq.push(['trackPageView']). - Paste the modified tracking code inside the
<!-- Matomo -->
<script>
(function() {
var u="//matomo/";
</script>
Install the Matomo cookie consent handling script
The following script listens for consent updates and enables/removes cookies when cookie consent is granted/denied. Add the consent handling script before the closing </head> tag on all website pages that contain the Matomo tracking code.
<script>
return;
// Initialise Tarteaucitron after the tracker is loaded<script>
"type": "analytic",
"js": function () {
"use strict";
console.log('Matomo cookies accepted');
"use strict";
console.log('Matomo cookies rejected');
</script>
- In the Visitors > Real-time report, check that tracking requests are still sent.
